TwinTurbo.NET: Nissan 300ZX forum - Check the fan relay before anything else
Subject Check the fan relay before anything else
Posted by aLL_youR_Z_aRe_beLOnG_tO_uS on May 08, 2014 at 6:24 PM
  This message has been viewed 179 times.
In Reply To What could cause the aux cooling fan to always run? posted by Marshall on May 07, 2014 at 03:50 PM
Message You can always swap an identical relay with the same numbers on it to test it, common problem on all cars. If your A/C is turned on this can make the fan run to cool the condenser, if so, turn the A/C off.
